19-03-2022 01:27 PM in
TVHi,
My Samsung TU7100 (model number: UE43TU7100KXXU) keeps muting and i dont know why. It started when I thought I accidently pressed the mute button but the problem seems bigger. It now keeps on muting mid programme and whenever a new episode starts. Additionally the mute symbol occasionally appears in the corner and flashes. My boyfriend and I have tried to resolve the issue with no luck and it is ruining our viewing experience. I dont know what has happened or how to rectify this. The TV is only about 2 years old. Has anyone else had this issue. Can it be resolved?
Any help appreciated
19-03-2022 01:45 PM in
TV19-03-2022 01:46 PM in
TV19-03-2022 01:49 PM in
TVHow do I check this? Also it's intermittent and not all the time.
19-03-2022 01:50 PM in
TVNo, I don't believe it is this I'm afraid.
19-03-2022 02:05 PM in
TV19-03-2022 04:11 PM in
TVif there is no setting to Mute volume best to check connected Devices setting. There is an option to receive a prompt every time a device wishes to connect to the Tv, the proviso is of course that at times it may your own device of course. This is accessed via Settings-External Device Manager-Device Connection Manager. May be advisable to change wifi password in any case.
otherwise check you have the latest firmware which is 2200.9 which was just released last month, if you do not have it it can be updated via USB. https://www.samsung.com/uk/support/model/UE43TU7100KXXU/ Another idea is to factory reset your TV.
One Ui 5.0,Android 13 .
19-03-2022 06:31 PM in
TVHi,
It isn't a problem with someone controlling or accessing the TV. I've checked all the settings and they're fine. It is really strange. You can watch a film no problem but if a series is on it will mute midway through or if the episode changes. Iam not sure if it is a netflix thing now?? I do believe it is the TV still though.
19-03-2022 06:32 PM in
TVLooks like there isn't a resolution. I will have to check warranty and contact Samsung. Out of ideas now. Thanks everyone
19-03-2022 06:42 PM - last edited 18-12-2022 12:58 PM ) in
TVIs it happening on any on any other apps or Freeview /other Tv ? You could try reinstalling Netflix if that has not been done already and disconnect Router for a minute. out of interest have you tried a Factory Reset? Anyway obviously can contact Samsung for advice.
