Tv help - all of a sudden my tv will not connect to the internet
(Topic created on: 08-09-2022 01:21 AM)
Aftan Hagen
Tv model : UN50MU6070
all of a sudden my tv will not connect to the internet, I know this is not a router problem as we have multiple devices connected to it and they are working
Tried unplugging tv from power source and waited a couple minutes, still nothing.
looking for some help  thank you
5 REPLIES 5
kkoke
YA same sweet dreams
Ginga_p
Troubleshooter
Have you tried both ways of connecting tv to router ie code and wps. Mine is fine using code not wps
G G
Aftan Hagen
Hi no I have not I will try looking that up on Google tonight to see what I will do hopefully it will help… Thanks
JAMES4578
Samsung Members Star ★★
Hi @Aftan Hagen   A few other things to try.   can you check you have the latest firmware which is 1310.1, though this is a US model(we are part of the European communities).  https://www.samsung.com/us/support/downloads/?model=N0052233
other ideas are  Resetting Network, a Factory Reset, Rebooting Router (via unplugging)  and changing the DNS Settings .  Change from Automatic to   to 8.8.8.8 or 8.8.4.4. (Google servers) or 208.67.222.222 or 208.67.220.220 (Open DNS).
SidOV
This seems to be a common problem with the Samsung TVs. I am having the same issue and I have tried everything suggested.
