Tv has a dark section
(Topic created on: 24-12-2019 06:31 AM)
Michaelw87
My tv has just started to have this dark section after 13 months, can anyone advise on what it is or reccomend any solutions to fix the issue.20191221_195449.jpg
5 REPLIES 5
AsadM
Hi @Michaelw87. Thanks for reaching out. Have you tried contacting the Samsung call centre for further assistance on this? They can be contacted on 0333 000 0333.
White62
My 75 inch Q6 led started showing the same thing this evening were you able to remedy that problem?
AndrewL
@Michaelw87 @White62: If you have completed a picture test and it has failed in all 3 instances then I recommend reaching out to our AV Team on 0333 000 0333 where an advisor will be able to assist you further. Alternatively, please contact a Samsung Support Centre to arrange for an engineer to inspect the device. To find your nearest one please check the link below, select 'TV & AV > Television' and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
White62
I am here in the states is there an AV team here? Or just contact a Samsung support center
AndrewL
@White62: If you're based in the US then please contact Samsung US via the link below for further assistance.
https://www.samsung.com/us/support/contact/
