12-04-2019 01:23 PM - last edited 12-04-2019 06:38 PM ) in
TVI have just turned off the tv, to clean the screen, and when the tv was turned back on there are 2 very noticeable dark shadows at the bottom edge of the screen, near the middle.
These are so noticeable when there is a light background, that it's impossible to ignore them. I enjoy lots of sport, and these shadows make watching any sport particularly annoying.
Does anyone know if there is a possible solution to this, as the tv is no longer under guarantee.
18-04-2019 02:27 PM in
TVHi @Slainagain
Are you still having this issue? What's the model code and software version of your TV? Go to Menu > Support > Contact Samsung, or for newer TV's, Home > Settings > Support > About This TV.
Are you able to send us a photo?
19-04-2019 07:14 PM in
TVTv still has the issue, so it seems permanent.
I made sure the latest software update was installed, and did the tests in the TV's options.
Here are some photos, one shows the fault at the bottom of the screen, the other is the model code etc.
19-04-2019 07:18 PM in
TV
