Tv fault
(Topic created on: 19-09-2023 09:04 PM)
SG111
My TV won't turn off it has a black screen which intermittently turns grey and buzzes quite loud. If I were to try and fix it myself does this sound like a power board problem?
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @SG111  you do not name the model but just check you have the latest firmware on Samsung support  https://www.samsung.com/uk/tvs/   Are connections/cables secure, have you  disconnected Tv and tried again,  best to leave around 5 minutes.   However it does not look promising with a loud buzzing noise as well, may well be a power board issue.  I would not suggest trying to fix a power Board yourself if other troubleshooting fails. on other other thread you mentioned additional warranty via rgb, noticed on current  available models  the warranty via  customer registration.
One Ui 5.1,Android 13 .
