12-06-2023 10:22 PM in
I have recently bought a Samsung 43 Inch UE43CU7100KXXU Smart 4K UHD HDR LED TV.
For the price it is OK, but was wondering how to improve a couple of things.
Firstly, the picture changes slightly when I move around the room. If I sit at sofa height, looking straight at the screen, it seems the colours are more vivid and it seems a bit darker. As I move to to a wider angle the image becomes increasingly brighter and the colours more faded. Is this standard, or can something be done?
Secondly, the sound is a bit weak at the lower end. On my old Sony the sound was clear at around 12, but on the Samsung 18 seems to be the same level. Any advice?
Thanks in advance.
27-07-2023 09:20 AM in
Hi, have you been able to set up Bitby or Alexa. Sorry this does not answer your picture question
