TU7020 issues
(Topic created on: 16-05-2021 05:58 PM)
JimmySB
Hi
I recently bought the 50 inch TU7020 smart TV and it seems to keep freezing/the remote not working? The Disney + and Amazon Prime apps also don’t really work - again, the tv freezes or it stops running the app and cuts to the Samsung TV.
anyone else had this issue or able to advise on how to resolve it?
thanks
5 REPLIES 5
CarlH
Hi @JimmySB. Is your TV up to date? Please confirm the latest software version you have installed. You can find this by pressing the Home/ Menu button on the remote and going to Settings > Support > About this TV. The latest version is 1420.0.
JimmySB
hi @carlh. thank you for your reply.
the software version is T-KTSU2DEUC-1465.4
i have already tried to update the software, but it says there are no new updates
CarlH
Are you connected wireless or are you using an ethernet cable from your TV to the router?
JimmySB
Connected Wireless
JimmySB
@Carlh any idea how I can update the software?
