28-07-2020 11:33 AM in
TVSo wanted to add this to help others
I've had the "too Dark" issue since getting the TV.
I have found the Engineering Menu fix works..... for most sources
https://www.youtube.com/watch?v=r-5Q88jgJFs
But I still have problems with the Netflix App itself, the input app is sooooo dark its almost unwatchable in dark scenes.
I have tested this against the Netflix app on my YouView Box and found that the YouView one is perfectly fine..
So not a fault of the TV, just the TV software and the 3rd party Apps...
28-07-2020 11:22 PM in
TVWorth updating the firmware to the latest 1302. Made a big difference for me.
29-07-2020 11:06 AM in
TVIs that available for the Tu7000, can't find it on the download page for my TV
15-08-2020 06:42 PM in
TVI have the same problem, called my Salesperson and he just asked me to change shadow details to higher setting and it works!
