03-09-2020 10:26 AM
Hi, I've bought a new 2020 Frame 65" and have it installed on the wall in the kitchen.
Happily watching for a couple of weeks and then all of a sudden, a high pitched squeal, the picture looked like it had dropped in the ocean, and now it can't get passed 'THE FRAME' text when you start it up.
There seems to be a 'click' from the One Connect box every few seconds as the TV powers up, fails and powers down. Every time I turn it on it does something strange. See some pictures of where it is, and what happened once with 'THE FRAME' text.
I also have a Q90R in the living room, I've swapped the one connect box, to see if that was the problem, no luck!
Any advice would be great!
Thanks,
Adam
03-09-2020 11:46 AM
03-09-2020 12:10 PM - last edited 03-09-2020 01:10 PM
Hi Tanvir,
Thanks for the reply. Yes, tried that.
It seems to be ok now after being turned off at the wall for 2 hours. But I don't feel that's the solution.
03-09-2020 02:07 PM
Back to square one. Squeeling, crackling, picture off.....dead.
