Go to solution Solved
The Frame (43LS003) : wich frame ?
(Topic created on: 19-06-2018 09:31 AM)
Proktor
Hi all,
I've bought the Samsung "The Frame" 43" (43LS003). I'd like to know from wich serie the frame come :
- MU6000
- MU7000
- MU8000
I also looking for good advance settings
Any idea ?
Christian
JAMES4578
Samsung Members Star ★★
Hi @Proktor,  As far as best settings go to a degree a matter of personal preference but you can base it on expert recommendations ,  still can take a bit of tweaking until you're satisfied.  I will enclose a  few links here for guidance which should be suitable.   https://www.rtings.com/tv/reviews/samsung/mu9000/settings   https://www.the-ambient.com/reviews/samsung-the-frame-tv-313
5 REPLIES 5
7alhoul
Navigator
Hi,
the frame is part of the series life style so this is another series of TV at samsung but if you want a comparison you can compare it to the serie MU9000 .
Proktor
Thanks
But if i look the spec, there's hugh differences :
The Frame
  • Color (Quantum Dot/Active Crystal/PurColor) : Active Crystal Color
  • 8 bits : ? not sure
  • HDR (High-Dynamic Range) : HDR
  • Motion Rate : 120
MU9000
  • Color : 4K Color Drive Extreme
  • 10bit Support : Yes
  • HDR (High-Dynamic Range) : 4K HDR EXTREME
  • Motion Rate 240
Proktor
Hi,
Here the answer of Samsung support for The Frame 43" :
- 8 bits avec un taux de rafraîchissement de 60 Hz
Christian
JAMES4578
Proktor
Thanks @JAMES4578 !!
