12-01-2022 09:27 AM
I setup the 32" to switch off when no light is detected into the room (and it works properly!) but...
...once the light is in the room again, nothing happens (and the screen stays dark).
No chance to have it in the Art-Mode again unless using the remote control.
Did anybody have this problem (and solved it)?
12-01-2022 10:03 AM - last edited 12-01-2022 10:04 AM
12-01-2022 11:38 AM
Hello Steve,
thanks a lot for your reply!
I would do it... if only my OneConnect would have a power button. 😞
It hasn't got any and... I fear... bigger model have the power button, so this is another difference the 32" version has got. Too many.
32" seems to be the unlucky brother of all of the others: no 2021 model, no motion sensor, no RJ-45 port onto the OneConnect... bah...
07-02-2022 09:45 PM
I am also having this issue!
After a restart, it will work as expected very briefly, but as soon as it sits “off” for more than a few minutes it won’t wake itself up.
05-08-2022 03:33 PM
Same here, with 75" 2022. Will not wake in the mornings
21-02-2023 08:17 PM
Same here with the 32“ model. Anyone solved this problem?
