Telly not straight
(Topic created on: 12-02-2023 11:05 AM)
Rhiann
Attached feet to tv and tv not straight. Have I attached feet correct way?! If not how do I get them out as now can't remove.
2 REPLIES 2
StuartR
Troubleshooter
They can only be on the wrong way round in my opinion, you need to look in the manual for the correct orientation which will also let you know how to remove the feet (usually clip into place then a couple of screws per foot)
Rhiann
Thanks Stuart just spotted the screws!
