23-11-2022 02:30 PM in
TVMy Samsung QE43Q65AAU smart tv sometimes will not change the station. The remote works fine and the selected channel number required very briefly flashes on the screen but the station does not change and stays the same.
Using the remote control up and down channels always works OK and after using that just to move either one channel either up or down, a channel number can be selected and then the station changes and all is well until another day when the problem may occur again.
Just annoying, any ideas gratefully received
23-11-2022 04:00 PM in
TVHi @Members_jlxKOii can check that you have the latest firmware which is 1430.6 which was released in October. It can be downloaded to USB and updated that way. https://www.samsung.com/uk/support/model/QE43Q65BAUXXU/
if you have this software or does not made a difference try unplugging from the mains for around a minute and try again. However if still issues you may need to Factory Reset. Settings-Support-Self Diagnosis-Reset.
One Ui 5.0,Android 13 .
