Sound stops briefly then turning the volume up/down
(Topic created on: 07-01-2024 07:29 AM)
JesperTP
Hi,
I have a TQ65Q64CAUXXC TV that are connected to my sourrondreceiver using the ARC HDMI port.
Sounds work fine when seeing something.
But if we turn the volume up/down the sound stops for 0.5 sec and then returning.
It happen as soon the image of volume change are showing
If we press the volume up/down button fast the sound shanges without interuptions, until the overlay shows up, the the sound stops for 0.5 sec.
How is that? It was not a problem with the old tv..
5 REPLIES 5
Ginga_p
Troubleshooter
In settings. Sound is it set to pcm
G G
JesperTP
No its set to pass-through
M3g60
Did you ever figure it out? I am having same problem. Thanks
M3g60
It’s the HDMI cable 100%. I replaced my cable and all good now
JesperTP
Hi,
No I have not figured it out yet. Do you know what the difference are on the two HDMI cables you have tried?
I did not have the problem on the old TV (Sony)
