Sound issue
(Topic created on: 12-10-2020 09:31 AM)
Matt-B1
Good morning.
I'm having sound issues with one part of my set up.
I have a Crystal Surround Air Track soundbar
QLED TV
BT set top box
My set up is :
HDMI from the set top box to the Tv
Optical cable from set top box to the Soundbar.
I also have connected a PlayStation and a DVD to the Tv also using a HDMI
sound can be heard as it should whilst watching tv, however if I then use the smart tv access to Netflix the soundbar still plays the set top box and does not pick up the Netflix sound. I have to turn off the sound bar and turn up the tv sound. The blue tooth on the tv doesn’t seem to find the sound bars BT🤷‍♂️
thought I was quite good at sorting this kind of stuff out.
any advise would be great and appreciate in advance anyone’s time.
matt
1 REPLY 1
AsadM
Hi @Matt-B1.
Hope you're doing well. Let's try going through the troubleshooting steps on this page to determine what actions to take to get this sorted: https://www.samsung.com/uk/support/repair/tv-av/
If you still experience any issues, it will be ideal to get in touch with our Support team. They can be contacted on 0333 000 0333.
