Go to solution Solved
Smart view on S7
(Topic created on: 08-12-2018 09:47 PM)
BIBURYBILL
Navigator
TV
Hi i have a new 43inch Samsung uhd 4k tv but smart view cant find it ?
2 Solutions
AndrewL
TV
@BIBURYBILL: What is the full model number of your TV? Similarly, what device are you attempting to mirror to the TV using Smart View?
BIBURYBILL
Navigator
TV
Hi the tv is a Samsung Ue43nu7020 I have smart view on my Samsung galaxy S7 and it just says no tv found .Can i ask something else I downloaded Samsung video and tv cast app to same tv it just said it had installed but i cant find it anywhere?Kind Regards Roy
3 REPLIES 3
AndrewL
TV
BIBURYBILL
Navigator
TV
TV
Smart view a13
