14-05-2019 10:28 PM
Hi My Samsung TV Model UE32D5520RK has just started to turn itself on and off. It seems to be trying to reboot, not possinle to change any settings as it won't stay on long enough. Have read about lots of Samsungs having similar problems. Would love to know the solution. Thanks
16-05-2019 02:49 PM
02-10-2020 01:15 PM
same problem after changing the power PCB
03-01-2021 01:08 PM
I have the same problem . Did you manage to find a solution?
03-01-2021 01:08 PM
Chris do you have a solution to this ?
03-01-2021 01:09 PM
Did you find a solution to tv turning off and on / trying to reboot ?
15-08-2021 06:46 PM
I have it too. Several videos on Utube show a memory issue which needs software from support site to reset. How can I access this? nThe TV is out of warranty. If I can't mend it it goes in the skip. 😞
