Support
Open search
Smart TV - Apps not appearing on scroll bar
Highlighted
When I press the home button I only get icons for Live TV & TV Plus across the bottom of the screen rather than the usual scroll bar where I would select the App
If I click on the apps button (far left in home menu)  most of the applications are available and work although interestingly there is no web browser.
7 REPLIES 7
Highlighted
BTTT Anyone any thoughts?
Highlighted
What TV? Have you tried resetting the Apps through the settings?
Highlighted
It's a UE43MU6100
Not sure how to reset apps through the settings but if you mean have I tried to reset the TV to factory settings then yes
Highlighted
Not sure if your settings are the same as mine...
If you go to Settings, Support, Self Diagnosis and should see the option to Reset Smart Hub?
Highlighted
You're a star, thanks
Highlighted
I have a question many apps dony appear in app store do you know what i should do
Highlighted
If you go to Settings, Support, Self Diagnosis and should see the option to Reset Smart Hub. Failing that do a reset on the TV?
Top Liked Authors
