18-06-2022 10:30 PM in
TVSo, I had a previous issue with some fizzing noise which was fixed by changing the board for my QEQ55700 8K TV.
However, now I have certain options missing. For example, I used to be able to check battery level by going into settings -> Power etc. That option is missing now.
I'm tired of these issues, TV is barely 2 weeks and causing more headaches than fun
Solved! Go to Solution.
19-06-2022 12:22 PM in
TVQuick reset and most options are back, have not noticed any anomalies since the reset.
