Go to solution Solved
Smart remote control for UE49K5600 with no IR port
(Topic created on: 12-05-2017 07:51 PM)
Mofowax
Hi, is there a smart remote control available for my UE49K5600 similar to the RMCTPH1AP1 or newer, as I really like being able to point with the remote rather than use the cursor buttons on the standard remote? I know the UE49K5600 doesn't have an IR port either, but I wondered whether there's an add-on accessory available to make this work.
Any advice appreciated!
CarolinaW
Voyager
Hi @Mofowax! Our Product Specialists have just confirmed that this TV model will not support a smart remote. Hope this helps!
2 REPLIES 2
CarolinaW
Voyager
Hey @Mofowax! We're looking into this for you. We'll be in touch soon! :robothappy:
CarolinaW
Voyager
