13-11-2021 11:07 AM - last edited 13-11-2021 11:08 AM
- Mute
- Highlight
Hi
I have a Samsung smart remote with Amazon Alexa built in. When I press the Alexa button/microphone, I can change volumes but not tv channels. For example when I say "watch channel 7" Alexa on the tv responds with "tuning to 7" however it doesn't change channels. It however works when I tell it to change the tv volume.
I have tried resetting the remote. Any advice?
TIA!
13-11-2021 02:16 PM - last edited 13-11-2021 02:17 PM
- Mute
- Highlight
This page maybe helpful to you
Use Alexa with your Samsung TV
https://www.samsung.com/us/support/answer/ANS00087622/
17-11-2021 12:16 AM
- Mute
- Highlight
Hi xSteveuk
No luck with those instructions unfortunately.
06-12-2021 08:50 PM
- Mute
- Highlight
I have exact same problem, the volume works fine but the channel doesn't change despite the screen showing 'tuning to 101' - so Alexa/TV recognises commands but TV does not tune - must be a bug somewhere, it used to work a few months back. Annoying.
30-01-2022 03:27 PM
- Mute
- Highlight
06-02-2022 07:17 PM
- Mute
- Highlight
I have same issue... Frustrating....
18-02-2022 02:40 PM
- Mute
- Highlight
I were using Alexa in my Q80T without no error for a year.
Since I have updated the TV firmware yesterday to 2200 versión, Alexa does not change channels anymore neither can open YouTube.
Alexa understands my voice commands answering that she is doing what I have requested but nothing happens. Changing volumen and switching off the tv still working.
18-02-2022 07:32 PM
- Mute
- Highlight
Hi,
I have gq85qn85aatxzg since 1 day in use.
And the same issues with Alexa, channels cannot be switched, but the sound level change works fine.
When I ask Alexa to switch to channel number 5, she responds like "I am switching to 5", but then nothing is happening.
During the TV initialization it was notified that there is a newer FW version available, so I have updated it instantly...
Samsung will do something against it?!
06-03-2022 11:43 AM
- Mute
- Highlight
Have same issue. Just purchased my first Samsung TV, and Alexa only controls volume. Everything else she says she is doing (like set channel 10) but it doesnt actually work. A bug that is easy to identify and would be good to know when a fix is due.
09-03-2022 04:31 PM
- Mute
- Highlight
I have just bought a Samsung Q80A tv yesterday and the same problem is happening to me ,, Alexa hears my voice and turns volume up and down but won’t change the tv channel . Alexa responds with okay but does not do anything …. Why is this happening ? Is it an update what’s done this and will it be getting fixed in a future update ??
