SMART HUB
(Topic created on: 15-03-2021 04:31 PM)
Airefose
HELLO,
PLEASE HOW CAN I ACTIVATE THE SMART HUB ON MY SAMSUNG 55" SMART 3D LED-TV ES6305
MODEL CODE: UE55ES6305UXXE
SERIAL NUMBER: ***********
2 Solutions
TessM
Mastermind
Hey @Airefose ,
I have had a look at this TV manual and you should be able to access Smart Hub from the TV Menu> Support> Smart Hub. Check page 344 on this manual for more information: https://downloadcenter.samsung.com/content/UM/201211/20121110095845360/01-XTDVBEUE-ENG-1109.pdf
JAMES4578
Samsung Members Star ★★
Hi @Airefose  Further to @TessM 's post have you previously set up a Samsung Account,  if not you will need to create one. Some more information here https://www.samsung.com/uk/support/tv-audio-video/what-is-smart-hub/   Advisable to check that you have the  latest firmware as there was an update May 2020 to 2010.0  and if you  do not have this it can be downloaded via USB  https://www.samsung.com/uk/support/model/UE55ES6305UXXE/
if after following instructions there are still problems I would suggest a Smart Hub and/or   Factory Reset.
One Ui 5.1,Android 13 .
4 REPLIES 4
TessM
Mastermind
Hey @Airefose ,
JAMES4578
Airefose
Thanks for your Response it was very helpful
JAMES4578
Glad it is now sorted out @Airefose .
