Smart Hub "updating" at power-on untill wifi connection is established
(Topic created on: 31-12-2017 01:56 AM)
sebkob
TV
I have an annoying problem after an update. Previously I was able to enter Smart Hub instantly but now I have to wait 30 seconds every time untill the tv powers on and the wifi connection is on.
The issue is replicated as follows:
  1. Power-on of the UE55F8005ST TV
  2. Push "Smart Hub" button on the remote control
  3. The tv will post the message: "Please wait .Smart Hub is updating"
  4. After 20-30 seconds the wifi connection is established I can enter Smart Hub with the button.
Is there any way to by-pass this online check that Smart Hub is performing at each start-up? Or should this be reported as a bug?
NOTE: Samsung have performed a remote "hard reset" of the TV with no luck
Regards,
Sebastian
0 REPLIES 0
