Smart hub is being updated. Please try again later.
(Topic created on: 08-01-2019 12:54 AM)
Khim
Hi my samsung smart tv is suffering form this problem for a month now. Can some tell me how to fix this?
93 REPLIES 93
Great_1
How can you do it with the  joysitck style button on the back for power?
vanrob
Hi, I guess you should press it...
jerree
I have a UE40F6320AKXXU with the little joystick rather than an ON/OFF switch. Trying the joystick and the remote control did not work. The suggestion from Crookie to access the Service Mode worked a treat. At last back to having a 'smart' TV.  Thanks for that.
TheTimK
THIS IS THE SOLUTION!!! Thank you, thank you...
100 extra credit points go to you, Kiwi!!!
dragonsun
hey, im from the future and is having the same problem as yours. Did you managed to find a solution?
HK10
Awesome! Worked, you are the best! thank you
Dustinswifey2019
Hey my TV is Q60T I just bought it and can't download apps cause smarthub keeps says updating, please help
ChrisM
SuperStar
Hi @Dustinswifey2019
Could you check that you've accepted all the T&C's? Go to Home > Settings > Support > Terms & Policy.
WillH5080
Hey! I have QN55Q60TAFXZA (this first one https://www.bestadvisor.com/3d-tv-smart-tvs ) and smart hub reset helped.
vanrob
Hi!
Give a chance to the REAL hard reset:
Turn OFF your TV. Press the physical ON/OFF button on the TV (most probably the joystick button on the back) for at least 3 seconds, then press the ON/OFF for at least 3 seconds on the remote within 10 seconds. TV must restart 2 times, and goes back to virgin factory mode. By other words, it will erase the EEPROM (store of the apps), settings.
If you success, you should have again at least 30-40% free memory which is enough to download (and store) the HUB app.
Yeah, and switch OFF the auto update of the installed apps...
