Smart Hub Error 301
(Topic created on: 05-07-2019 12:04 AM)
Twinkletoes
Hi guys, my TV, model UE49HU6900 keeps displaying an error 301 code when I try to use the smart hub? My software is reported to be all up to date? I've gone through the hub reset process which still doesn't work. The TV shows full internet connection and is hard wired.
Any help and advice would be greatly appreciated please
4 REPLIES 4
gandrew
i am having same question. Hope to get an answer here
ChrisM
SuperStar
Hi @Twinkletoes and @gandrew
Let's try a reset on both the TV's. Go to Menu > Support > Self diagnosis > Reset. You'll be asked to enter a 4 digit PIN code which is usually set to 0000, unless it's been changed. Note the reset will lose any changed settings that have been made to the TV and set them back to the default settings.
Let us know if this helps.
JohnF3
I have the same 301 issue on a UN50TU690TFXZA - my authenticated Samsung account will not allow me to download apps.  The "reset" option under "General" is grayed out and unavailable to me.  Please help me with this issue
Bunny flower
Hi I have the Samsung UE50RU7020KXXU it’s showing error code 301 also I have reset it and rest the smart hub but still no joy
