Sky Q HLG Samsung UE65TU7020KXXU
(Topic created on: 27-08-2021 09:21 PM)
SteLFC
TV
I’ve just bought a new Samsung TV - model UE65TU7020KXXU - and I’m trying to change the gamma settings to HLG for use with Sky Q. However, when I go to the settings, the option is greyed out. I can choose 2:2 and BT.1886 but not HLG. I’ve got Input Signal Plus turned on too. Could it be something to do with my HDMI or something else? Thank you.
1 REPLY 1
antikythera
Hotshot
TV
Try with the sky box disconnected or simply turned off. It may be a setting that can only be changed when a device is not sending a signal to the TV. Some HDMI related settings are like that on many TV brands including Samsung, LG, Panasonic and Sony from experience.
