several problems with new q80t
(Topic created on: 17-09-2020 06:11 PM)
popop
I am currently with the Q80t update version 1304 and it has a number of issues:
1. It have color banding ..this is an image that illustrates the problem (my situation is at the left end):
https://i1.lensdump.com/i/00arK1.jpg
And these are pictures from games (both on the PlayStation 4 and from my pc so it sure is a problem on the tv) that illustrate the problem:
https://lensdump.com/i/00GKXH
https://lensdump.com/i/00G4Hx
https://lensdump.com/i/00G7r1
Of course, this also happens when watching movies in dark scenes.
2. When I try to turn off the game motion plus settings all the colors become inverted as in the negative of images:
https://lensdump.com/i/00GziZ
https://lensdump.com/i/00GS9P
i replaced a q70r that have a DSE and didn't have these kind of problems i mentioned early on. this is absurd! are you going to release a firmware update that will fix these issues or i am just will have to get a full refund and move to sony?
Tags (1)
1 REPLY 1
lmpcardoso
Pioneer
Same problem here, and its not been fixed with the recent update. I will wait for the next update to see if all this problems are solved, if not I will return my TV Q80T because the TV does not do what they say it does.
