Set Up Voice Assistant problem
(Topic created on: 14-07-2024 10:43 PM)
Knucklehead 2023
I have a Samsung QE65QN95A  (2021) 65 inch tv. As of approximately a week ago the Voice Assistant settings are no longer accessible in the menu. I first noticed it when I used the voice control button on the remote to give a command and a pop up menu came on screen saying Set Up Voice Assistant.  Alexa was set up as the default voice on the TV originally. I have read that Google Assistant is no longer supported lately but Alexa should still work right? Anyone had this issue?
Thanks
22 REPLIES 22
Robin999
Legend
Is Alexa still one of the options in the Voice assistant menu? If so, have you tried setting it up again?
Knucklehead 2023
Voice Assistant settings are no longer accessible in the menu. When I click on the setting it says Set Up Voice Assistant, I click OK then it goes back to Set Up Voice Assistant again that’s all it will do.
Robin999
Legend
Thanks. Is your TV a UK model?
Knucklehead 2023
UK model yes, also there is no software update available for the TV
scoobe23
How do I keep Masseges
Robin999
Legend
Hmmm, maybe Alexa has been removed then? Ive had a look online and can't find any info about which voice services are no longer compatible with your model, sorry. How about a full factory reset? Is that something you could try?
AndrewL
@Knucklehead 2023: Is the TV connected to the internet, and are you signed in to your Samsung account (Settings > General > System Manager > Samsung Account)? If not, then please connect to a stable Wi-Fi network, sign in to your Samsung account, then head to Settings > General > Voice > Voice Assistant, and Bixby should be available as an option. Alternatively, press and hold the microphone button on the remote, say a command, then release, and this should run the set up if an assistant is not assigned.
Knucklehead 2023
Hello, I have tried everything including a full factory reset involving unplugging the tv from the mains and holding down power button on the remote.
Robin999
Legend
Thanks, the only other thing I found was Bixby. Is that something you could try instead?
https://www.samsung.com/us/support/answer/ANS00088583/#:~:text=Your%20Samsung%20Smart%20TV%20comes,l....
