serial number
(Topic created on: 19-05-2017 08:38 AM)
gwyn
i have purchased a 32" HD TV refurbished & i need to insure the tv but i can't find the serial number i contacted the seller & they said it had been removed.
ChrisM
SuperStar
Hi @gwyn.
You can get this through the menu of the TV. Go to Menu > Support > Contact Samsung.
6 REPLIES 6
ChrisM
SuperStar
Hi @gwyn.
Ammels
I have just purchased a UE32T5300AKXXU however when I register the device through the TV on  my profile it comes up as Serial number : TEST_SERIAL_NUMBER.
However on the back of the TV the serial number is *******
Is anyone able to advise on this discrepancy please - is my TV correctly registered with Samsung ?
thanks
AndrewL
@Ammels: Due to data protection I have removed your serial number from your previous post, as it is a key identifier of the device.
Do you have access to a Samsung mobile device? If so, swipe up from your Home screen > Samsung (folder) > Samsung Members > Get Help > My Products. Is the TV listed here? If not, tap 'Register' and follow the on screen prompts to see if you're able to register the device via this channel.
Ammels
Thanks for you reply Andrew - I do not have another Samsung device so am unsure how to register this TV
TessM
Mastermind
That is fine @Ammels , can we ask when and where did you get the Tv and if there is anything wrong with it?
Ammels
Hi - I bought it on eBay and absolutely nothing wrong with the TV but just wanted to get it registered with Samsung.
