07-11-2022 02:48 PM in
TVBought a new tv QE50Q65BAUXXU but when I try to register it then it says invalid serial number. I checked on the box and on the back of tv its same. help will be highly appreciated.
Solved! Go to Solution.
07-11-2022 07:15 PM in
TV07-11-2022 04:06 PM in
TV@Jasim11, Contact with local Samsung support. They should check your serial number and eventually add it to database.
07-11-2022 04:07 PM in
TVThanks Kamil. I check with them.
TV07-11-2022 07:47 PM in
TVThanks GG... Its sorted
07-11-2022 07:50 PM in
TV30-12-2022 03:19 PM in
TVThat doesn't work either
30-12-2022 03:28 PM in
TVThe serial number on the box has one character missing compared to the serial number quoted on the tv information on screen, added the one character, all ok
a week ago in
TVWhat character did you add - and where?
