16-01-2021 09:46 PM in
TVHi, I have ua40j5500 for the last 5 years, screen merroring used to work fine, but since 1st January 2021 I can no longer connect any of my devices. Non of the devices cannot find the tv. TV is connected to the same wifi. No problem to case from device to TV, like YouTube or Netflix.
Sometimes I found that the screen mirroring menu is disabled and only enabled after I turn off and on the TV, but even then no luck to mirror.
Again, this is only after January 1st 2021!!!
Any help please???
Maybe bug with current latest version?
18-01-2021 01:00 PM in
TV18-01-2021 09:22 PM in
TVHi Flipit, I have 3 different mobile devices and none if them finds the TV.
If you hear from them, please let me know what their answer is.
18-01-2021 09:51 PM in
TV25-01-2021 03:54 AM in
TVHi Flipit,
Thank you for informing me.
Unfortunately, since I have 3 different mobiles and non of them use Android v.11 (one is even using Android 10), I'm sure that the problem on my side is with the TV itself and not the mobiles. Also, all 3 stopped connecting at the same time, so probably a TV / TV version issue.
