Satellite manual settings firmware problem
(Topic created on: 03-01-2020 03:41 PM)
Karabantas
 I need to report a problem in the Samsung FHD SmartTV with built in receiver Satellite manual settings that will require a firmware development and upgrade to be fixed. I explored that whenever I need to add any new or user-defined satellite transponder frequency which does not exit in the satellite existing default transponders list, the new transponder frequency should has at least 10 MHz difference from any existing frequency in the default list if it has similar polarization. But if it has less than 10 MHz difference, it won't be accepted and accordginly won't be added into the transponders list and cannot be used. Unfortunatly, this is creating a probelm for me while trying to add some new transponders with less than 10 MHz difference from existing ones and these new transponders and their channels cannot be added accordingly. To make it more clear here is the example:
Existing Satellite Transponder list has the following frequency: 11476 MHz V
New or User-defined transponder that cannot be accepted or added after several trials:  11467 MHz V or 11468 MHz V or 11469MHz V ....... 11475 MHz V. In such case, the maximum frequency that can be added is 11466 MHz V which cannot have the same signal quality of my target frequency of 11470 MHz V.
I am not sure how I can report this problem to Samsung to be fixed and have a new upgraded firmware version with that fix accordingly. My FHD SmartTV model is UA43N5300 with the latest firmware upgrade but i tried the same in other models and found the same problem exists which means it is a common problem in several existing formwares.
5 REPLIES 5
Karabantas
I just need to add that there is no option as well for deleting an existing transponder or wrongly added one from the satellite transponder list which need to be an available option as well in the new software.
Kiwi_Tim
I have a similar problem. I am in New Zealand. My elderly Aunt has recently purchased a UA43RU7100SXNZ. She likes a particular channel from the Optus D2 at 152.0 E. This satellite is not listed, so my only option is to use a User Defined satellite. Although it is possible to manually edit the Frequency, it is not possible to edit the Symbol Rate outside of preset values. When I go to save my edits, and then scan from the User Defined satellite, I get the message something like "no transponder", so it seems that my edits are not being saved to the User defined Satellite, despite me clicking the save button. It seems that the Satellite Scannning part of the OS needs some work.
Further more, why not just include a blind scan option, like most satelite set top boxes, then people don't need to edit transponders?
I wish to request that Samsung adds Optus D2 at 152.0 E. to their satellite lists in the next firmware update.
MR_T80
Is the software the same as my samsung? ks6000 series.
Ive struggled to add a transponder on a user sat today.  But think I have found a work around.
Run a search.  When no channels are found, manual search via Expert settings
it gave me the option to select the satellite and manually input the frequency, symbol rate and polarity details.
rtl
The suggested fixes don't work either, the software on samsung tv's has become so poor I wonder if it's even worth trying to fix or better to just buy another make of TV. I even changed Motherboard complete because of tuning problems and the new one was no better. Really how can such problems happen, are Samsung just trying to save money, but in the process losing customers.
Aslam 187
I'm from Pakistan.
I buy samsung smart tv q70b55ba on 27 April..
Same fault and not search C band and Ku band channels Auto and manually..
What is doing Samsung with buyers...
