I have just purchased a ue65au900 TV How do you switch the sky box off using the TV remote? It does everything else but don't know if you can do this. Thanks
To turn your Sky±HD box to off, press and hold the standby button for 5 seconds on your remote. The standby light on the front panel is red when your Sky±HD box is plugged into the mains but turned off.
