Samsung ue50au9007k
(Topic created on: 17-01-2022 07:59 AM)
alienkarper
TV
Hi I wonder if anyone can help me please i have a samsung ue50au9007k and can't find out how to run my ps5 in 120hz it's running in 60 hz i have the hdmi in Earc is this correct ? as Im not sure and as it got tobe a 2.1 hdmi cable thank you for any help
3 REPLIES 3
xSteveuk
Maestro
TV
Hi,
This page maybe helpful
How to Connect PlayStation 4 and 5 to your Samsung Smart TV
https://www.samsung.com/au/support/tv-audio-video/how-to-connect-playstation-4-and-5-to-your-samsung....
BIBURYBILL
Navigator
TV
Arc is for sound systems
AndrewL
TV
@alienkarper: I've had a look into this for you, and the ue50au9007k does support 120hz refresh rates, but not at 4K. You'll still be able to get 4K @ 60hz on all HDMI ports, however. HDMI 2.1 support is provided on the eARC port, which I believe is HDMI2 (although it should be clearly labelled). 120Hz at a reduced resolution may still be possible, therefore please check your PS5 Video output settings, and adjust them accordingly.
