Support
Open search
Samsung ue46f6740 TV speakers & 3.5mm headphone simultaneously?
Highlighted
Hi,
Can anyone suggest how I would connect a pair of headphones to the 3.5mm output and not lose TV speakers?
I have read that I could use a Digital to Analogue convertor, anyone have any suggestions on the prefered connection's? I believe I can do toslink > d2a > 3.5mm jack, this I believe will keep the TV speakers working...
Hope someone can help.
Thanks.
2 REPLIES 2
Highlighted
Pathfinder
Hello,
you can use an optical adapter / jack to connect your headphonesand you won't lose TV speakers.
you plug it into the optical port of your TV.
I hope that my answer will be useful to you.
Highlighted
@Zakaria_E wrote:
Hello,
Cheers for the reply.
I have an inexpensive d2a USB adapter coming from eBay this week, so will keep you updated on my progress.
Top Liked Authors
