25-05-2017 08:45 AM
I also have a Samsung UE40ES6300 TV and yesterday it suddenly stopped finding my or any other wireless nestworks.
I have reset the router, factory reset the TV and it still won't find any wireless networks. I suspect the wireless card in the TV has failed.
I also have a UE40ES5500 TV and that suffered the power cycling issue. We paid to have that fixed, but then over time found that Amazon Prime, Netflix etc were no longer supported and the apps were removed from the TV without any warning. We bought the Smart TV for those services and similar services and to find that within a year or so, services were just removed is appalling.
I suggest that someone from Samsung contacts me to explain or resolve the issues above, because as it stands at the moment I do not rate Samsung build quality, longevity in service, or customer service highly at all. I will not buy any Samsung products again - that goes for TVs, consumer products, mobile phones, tablets or PCs. Someone at Samsung needs to realise that these are expensive items and the fact that they just fail after a year or so in service is not good enough. They seem to treat these items as disposable items with a working lifespan of 1 year.
19-01-2021 04:59 PM
Wow thank you. It's been at least 2 years since the wifi stopped working on my Samsung TV. I'd long given up and pay for Amazon Prime now and use a firestick to get wifi. Anyway I have just done the above and hey presto it worked and connected to my wifi! Brilliant. Kind of got used to having Amazon TV now though so might still keep it!
22-01-2021 04:50 AM
Thank you so much! I have 46ES8007 and I though that's the end of wifi, but your tutorial helped. Thank you !!!
09-02-2021 01:17 AM - last edited 09-02-2021 01:19 AM
Same issue ue32es6200 after updating wifi could be found. Works good with Ethernet cable but want to use it in wifi mode. WIFI Region was set to E, so changed to A but still dint work. Also the mode is displayed as DTV not MTV. Not sure if the Region depends on country too or its by default need to be A. Any suggestion on it or anyone fixed it. I am in Germany.
27-07-2021 05:11 PM
Hi I know you posted this a while ago but can you explain how you do that please
