21-05-2021 08:43 AM
My tv model UA48H6300AR is rebooting automatically every 10 minutes. Tried to reset but getting stuck on 3rd stage doesn't complete the 10 stages.. plz help how to fix if any new firmware or any trick which can be apply plz ?
Solved! Go to Solution.
21-05-2021 10:38 AM
Hi It can be downloaded from UA48H6300AR | Samsung Support Singapore
21-05-2021 12:29 PM
I'm not sure, sorry, I havent read the instructions.
21-05-2021 02:16 PM
21-05-2021 09:34 AM
21-05-2021 10:20 AM
Could you please send me current firmware?
21-05-2021 10:38 AM
21-05-2021 11:33 AM
Thank you so much dear your quick response.. once i download i have to save in USB and extract in USB as well ?
21-05-2021 12:29 PM
21-05-2021 02:04 PM
Plz help me to get proper update how to upload firmware thru usb. I downloaded from above link and extract the file in USB. While selecting the upload software thru usb it is showing invalid format and not located the file.. plz advise
21-05-2021 02:16 PM
21-05-2021 02:59 PM
Awesome awesome awesome...i will follow this.. one more help plz.. how i can create Samsung account as that all options showing greyed not visible ?
21-05-2021 04:06 PM
