06-08-2022 05:50 PM in
07-08-2022 01:47 PM in
@dutcho: Please can you confirm the model number of the TV, located in Setting > Support > About This TV, or on the sticker on the back of the set, and I will look into this further for you.
08-08-2022 06:16 PM in
09-08-2022 02:13 PM in
@dutcho: To begin with, please ensure that you are on the latest software by heading to Home > Settings > Support > Software update. This model comes with Google Assistant built it, so please try heading to Home > Settings > General > Voice > Voice Assistant > Google Assistant, and explore the available settings here to see if this helps.
09-08-2022 02:25 PM in
09-08-2022 06:53 PM in
@dutcho: For clarity, is Google Assistant available as an option when you follow the steps above. If it is, and if you're already logged in, try pressing the Microphone button at the top of your Smart Remote, and trying a voice command to see if this helps. If Google Assistant isn't there, then you may wish to consider utilising one of the available Voice Assistant options, such as Bixby or Alexa, and referring to the command examples to gain an idea of what's possible with the feature.
09-08-2022 06:58 PM in
