Samsung tv
(Topic created on: 22-06-2021 12:28 AM)
JTCFC
Anyone know how to get this bluddy Samsung TV plus to stop playing on my tv turn the tv on and it loads up automatically doing my nut in
4 REPLIES 4
xSteveuk
Mastermind
Hi,
Are you wanting to remove it?
This may help
Navigate
to the Samsung TV Plus app
and press the down button on the remote.
This will bring up two options
Navigate to 'Remove' and select.
Select the TV source
Open the channel list
Select the TV Plus channels
Delete the TV Plus channels.
JTCFC
Thanks mate will give that a try 👍
JAMES4578
Samsung Members Star ★★
Whilst Tv Plus can not be completely removed as integrated into the TV should be able to remove channels.  However will need to keep an eye on it as new ones may be periodically added.
Whilst this is a US link it may be useful  https://www.samsung.com/us/televisions-home-theater/tvs/tvplus/
JTCFC
Thanks
