Go to solution Solved
Samsung TV volume goes up automatically to 100
(Topic created on: 19-05-2020 02:59 PM)
Sayed2
I have a Samsung 55NU7300 and bought it just over a year ago and yesterday the tv seemed to gain a mind of its own and the volume would just keep going up and I couldn't stop it. I tried switching it off from the mains and left it for over an hour and trying to see if the auto volume setting was switched on but it didn't work. I'm not sure what else to do.
wasabipeas
I had the same thing happen recently with my QN90B remote. The volume would increase to 100 on it's own without me touching it.  I thought it was the Samsung remote or the TV just acting up so I went through the whole procedure of resetting the TV and, of course, that didn't work. Turns out it was my Apple TV remote that was causing problems. To fix it you just need to press the TV Icon button and the Down Volume button on the Apple TV remote and hold them in for about 10 seconds and that will reset the Apple remote. Since doing that I haven't had any problems and everything is back to normal.
34 REPLIES 34
MelC6
This happened to my Samsung tv yesterday too. I tried some of the reset suggestions online and non work.
is this just a coincidence? The tv is only 18 months old so I'd be interested if you found a solution!!
Sayed2
I really hope it's a glitch or something must have gotten shaken up internally as my tv hasn't done that since the day I posted my question on the forum.
CarloL
Hotshot
Hey! Does this issue occur when using apps or just randomly? Does it happen when you are using an external device connected to the TV? When the volume increases by itself, can you see the Volume Bar on the screen?
dmb68
Hi....I have the same issue and wondered whether you found a solution to this
rgds
Sayed2
@dmb68
Hi,
Since the day I posted this, I found that the best way to stop this from happening is to unplug your tv from the mains for a few hours or the entire day. It should stop doing that.
Gems26
Has anyone found a solution to this? Our Samsung UE55NU7400 has started doing this today and we have tried all sorts but been unsuccessful. Only Brought it in December 2018 😫
FatBonus
Hi There,
Our TV did this just now. I observed that the red light under the tv is flashing really quick. Seems like it's receiving IR signals from its remote control. So I took off the batteries and tv started to act normal. I did open tv remote app on my phone and it works perfectly manage to drop volume and it stays.
I think and hope its the remote that's playing up. Will try get a universal tv remote tomorrow.
Hope it helps. By the way your TV and your phone should be on the same wifi so your TV REMOTE APp will work properly.
lsitesgb
I unplugged everything for 3 hours and my volume still goes to 100 on its own.
ashwinds
Having the same issue with 55" Frame. But only with the optical out connection. The TV Volume behaves fine. Not sure why this glitch started recently. Did any of you figure out a solution? I noticed it happens only when I increase (or decrease) the volume beyond 1-2 steps. ie keep the remote volume control pressed. Earlier it would stop increasing or decreasing when I stopped pushing the volume key up or down. Now it wont stop until it touches maximum or 0.
