07-09-2021 12:28 PM in
TV12-09-2021 10:22 PM in
TVLong story .
Please check this forum for this problem.
I have up and now have Virgin media with possibility of recording 6 channels in same time without any issue.
best
darek
12-09-2021 10:51 PM in
TV13-09-2021 12:16 AM in
TVhi, your TV must be in live TV terrestrial, then go to settings, broadcasting, automatic tuning, do this and when you reach 20% just turn tv off, then turn on and proceed same automatic tuning to end. much faster. then your TV should be able to record if your hard drive is OK ( when you connect it first time tv should perform formatting)
13-09-2021 01:38 AM in
TV13-09-2021 12:46 PM in
TV@Helen22: Please can you confirm the model number of your TV? In the meantime, ,make sure that the correct time is set by heading to Settings > General > System Manager > Time > Clock, as this may be affecting the TV's ability to properly schedule the recordings.
13-09-2021 01:11 PM in
TV14-12-2021 09:22 PM in
TVHi. Does anyone have an update on this? I’ve had this message for months on most of my scheduled recording requests resulting in failed recordings each time. In fact scheduled recording requests made via the programme guide ALWAYS fail if TV is on standby. If the TV is switched on they are always successful, interesting. Also interestingly manual recording requests are always successful even on standby. I’ve tried the retuning with switch off after 20% to no avail.
14-12-2021 09:26 PM in
TV20-12-2021 05:57 PM in
TVI have exactly same issue with my QE55Q68AU. I bought it three days ago and now I start to regret it. I had tried all the tricks but scheduled recordings fails always.
