Go to solution Solved
Samsung TV Adapter
(Topic created on: 06-07-2021 09:11 AM)
agh551
TV
Hi, hopefully someone can help, I gave a 24" Samsung TV ( T24E310EX) to a friend around 12 months ago but forgot to gave the power adapter. I have found a adapter I'm not sure if it is for this TV. The adapter is an original Samsung A3514_FPN 35W. Is it possible to advise if this the correct adapter for this TV
AndrewL
TV
@agh551: I wasn't able to verify the model number of the power cable, however I was able to find the correct part on our affiliated spare parts site, which deals in genuine Samsung parts and accessories. To find out more, please check the link below. I hope this helps.
https://www.samsungspares.co.uk/tv-projector/t24e310ex-lt24e310exen/mains-cable-uk-plug/product.pl?p...
2 REPLIES 2
AndrewL
TV
agh551
TV
Hi Andrew, apologies for not replying earlier, I thought I had. Your link to the Samsung site, helped me solve the problem with the power adapter.
