19-12-2020 10:20 AM - last edited 19-12-2020 10:21 AM
Hi,
I am havinf problems ataching to a wall mount kit. Not the kits fault - the issue is with the tv itself. The top of the TV is slightly curved. TV instructions very u clear as the depth of the top 2 bolt holes are different to the botton 2 holes - it says it needs 40mm M8 bolts. (So do i need 2 different lenght bolts? TV came wiyh 4 adapters/spacers which made sense - but the kids lost them- i contacted samsung but they said my TV model does not come with adapters?????? I am totally lost now - i am afraid of damaging the tv if i use longer bolts. If any 1 has this tv how did you mount it - what size bolts and spacers did you use? Its a disaster at this stage it looks like im not going to get the tv on the wall for the kids dor the xmas. Any help appreciated.
