Samsung Smart TV
(Topic created on: 18-06-2017 02:45 PM)
tv5
I Have a new samsung smart tv.
It connects to router and works ok but after the tv has been turned off for a while, it seems to lose the wifi settings.
I then have to connect to the router again each time.
The ISP says that I have to contact Samsung to get some port numbers and then they can fix it.
Not too sure if they know what there on about.
Any ideas?
1 REPLY 1
ChrisM
SuperStar
Hi @tv5.
What's the model code and software version of your TV? Go to Home > Settings > Support > Contact Samsung. Are you using a wired or wireless connection?
