Go to solution Solved
Samsung Smart TV stopped connecting to internet (wifi and Ethernet)
(Topic created on: 17-07-2018 12:09 AM)
Bobik
Hello,
I am trying to fix my parents Samsung TV F6500 which has stopped connecting to Internet since a few weeks. Here is my diagnosis: The TV won't connect to Internet using wifi or Ethernet throught their usual provider. When I use my 4G phone as an access point, the TV connects normally.
These are the solutions I have already tried and that didn't work:
- Reseting the ISP's router + changing it's IP adress
- Factory reset of the Samsung TV (using the Auto-diag menu and the secret menu that you access pressing different buttons on the remote)
- Changing DNS to 8.8.8.8 or 8.8.4.4.
- Updating the firmware
- Calling the ISP's hotline
My questions are :
- Is it possible to do a factory reset that includes the Network connections?
- Has anybody had the exact same issue as my parents?
- Even after the factory reset, the TV continues to say that the firmware is up to date, is it possible to remove the updated firmware?
I am out of options and the Smart Hub is now useless. Any help would be greatly appreciated!
Go to solution
592 REPLIES 592
fabianzacharias
for me holding down the power button and entering 8.8.8.8 in the DNS adress worked
Members_6jfwRTh
Try disabling Anynet+. The setting is found in: Settings Menu/ General/ External Device Manager.
This worked for me seeing up a new Samsung TV. Prior to disabling this, I could only (re)connect to WiFi and the internet using WPS. All settings would be lost upon turning the TV off and on again.
Jcope
Tried all the fixes and doesn’t work.
new TV. Makes zero sense and so irritating!!
