Samsung Smart TV Keyboard not working
(Topic created on: 04-06-2019 10:25 PM)
ashoktamil
TV
Samsung Smart TV Keyboard not working . Model:UN40KU6300F.
Onscreen Keyboard appears when I open the Web Browser/Apps. But not able to type/navigate to any characters in the keyboard when I press Ok/Up/Down/Left/Arrow buttons in TV Remote. It does nothing when I press those buttons once onscreen keyboard appears.
The other keyboards in YouTube/NetFlix work fine when I press the Remote buttons. Appreciate your suggestions to resolve this issue. I have even tried to reset the TV by doing Self-Diagnosis. But no luck.
Thanks.
11 REPLIES 11
BocaProwler
TV
My KS9000 starting doing the same thing recently, not sure if it was after the most recent firmware update. I've fully reset the TV, I've unplugged power to TV for a while, still does not work. Netflix and youtube's keyboard work, but the Samsung built in apps (like trying to search for an app on the appstore or putting in an IP address under Network) don't allow me to move the cursor or select a letter.
giorgi2
TV
i have the same problem can anyone help us?
Scoto
TV
Did you fixed?
Newton47
TV
I have got this exact same problem did anyone find a solution
BocaProwler
TV
For me, on my KS9000, the solution was to replace the main board inside the TV. Once that was done the keyboard started to work.
Newton47
TV
Thank you for getting back to me .,the strangest thing ..we had a power cut last night and when the power finally came on and I was back on the internet the keyboard was back .. so fingers crossed it will be ok
thanks again
PremGurung1987
TV
I have the same issue on my TV. How did u got this solved ?
Newton47
TV
Hi I found that because the tv was with out power therefore switched off during a power cut it reset its self so when I switched it back on the keyboard was back hope you get it sorted
Kaan
TV
Hai friends same issues on my smart tv
But I cleared
It's YouTube update problem..
Jus go to tv
From ur TV remote
Press settings
Go to smart TV
Reset smart TV
Press ok
It will ask for ur password
1234 is the password
Don't worry evething will be cleared and updated
Now just try YouTube app with keybord
