04-11-2022 09:42 AM in
TVSince 'upgrading' to the QN900B a few months ago, we've had nothing but issues with the new solar smart remote. The first one repeatedly stopped controlling the TV at all. After receiving the replacement, the second one then started acting up as well. Specifically, the TV would not respond to key presses on the remote for up to 30 seconds after the TV was turned on, then later seemingly at random the TV would stop responding.
My initial concern, assuming that two consecutive faulty remotes is unlikely, was that the TV itself was faulty in some way. We then reverted to using the older model smart remote (silver/metal) which we still had from the previous failed Samsung TV. This is seemingly working consistently.
We can of course carry on with the old remote, but it mildly annoys me that a £7k TV doesn't work properly with the supplied remote. Also the new solar remote was supposedly a 'feature', one that we now won't benefit from.
Will most likely raise it again with Samsung, but wondered if others are seeing any issues with this specific remote model.
04-11-2022 10:24 AM in
TV04-11-2022 11:39 AM in
TVSorry I should have added above, on each occasion the TV reports the remote is *at least* 50% charged. With the first remote that failed, the remote was fully charged via USB-C before use, so it was never a case of low battery.
04-11-2022 09:09 PM - last edited 05-11-2022 04:43 PM ) in
TVI do not work for Samsung or make Samsung Products but provide independent advice and valuable contributions.
One Ui 5.0,Android 13 .
05-11-2022 10:25 AM in
TV05-11-2022 10:37 AM in
TV*Very* interesting as that is exactly what we're finding. We're also using a 75Q900B, so same size and model. I've not yet gone to the lengths of having the TV replaced, but must admit I'm not far from it. We've had terrible problems (ongoing) with the TV not recognising our Sonos Arc soundbar, but that may now be related to yet another device acting up.
The remote issues seem a definite pattern though. I even tried pairing the solar remote to a Frame TV we have in another room and it was flaky with that as well. Fortunately I had two remotes from the previous Q950TS, so I now have one of those in lounge, one in bedroom. Both are working ok thus far.
What other issues prompted you to replace the Q900 multiple times, out of curiosity?
05-11-2022 10:46 AM in
TVHi James,
Yes I'm aware of the various ways to charge the remote. We've charged using all of them, it makes no difference to the 'flakiness' of the remote - in fact charging by USBC seemed to make things worse.
And yes the TV has been power cycled multiple times. We've even done multiple factory resets on it due to this and other issues.
I'm inclined to think much of it is firmware related (and therefore possibly fixable), but how long should I have to wait for a £7k TV to work consistently?!
05-11-2022 04:48 PM in
06-11-2022 12:08 PM in
TV07-11-2022 04:00 PM in
TVI feel your pain, and I completely agree. We've had the top of the range 8k, before it top of range curved/4k, and each time we've had either tons of issues, or complete failure within an unreasonable timeframe. Fortunately we tend to buy our TV's from John Lewis, so have a 5 year guarantee, but that doesn't make it much easier. It's still a battle proving any issue, and then you tend to only get the 'current value' of the TV toward a replacement.
Frustratingly no one else I'm aware of does the external box and oneconnect. Without that, wall mounting is a total p.i.t.a.
Also frustratingly I'd say these issues aren't isolated to the top of range TV's. We have a 43" Frame in the bedroom that now randomly refuses to power on via the remote. Only fix is pulling the power out of the oneconnect box. Once the main TV is sorted I'll be moving on to tackling that one next. 😞
