24-09-2022 03:21 PM in
TVI have a Samsung S95 65 inch OLED tv and I'm extremely pleased with. Amazing picture, impressive sound quality, lots of features and control. However every time I switch the TV on from standby into terrestial TV, the picture and sound are way out of sync. As soon as I change channel it fixes itself. I have a HDMI cable to my audio amplifier (using e-Arc) although I don't use it by default. Has anyone had the same issue and if so is there a fix? Turning on the TV there must be several seconds delay between the picture and sound. As soon as I change channel though it's fine.
Simon
#samsung s95b
07-01-2023 06:11 AM in
TVExactly the same problem here, tried resetting the sound but still happening. Sound resynchronises if I pause and play but it's really distracting and happening more often on pre installed apps. No soundbat attached. Only had the TV a month. Help!
07-01-2023 03:24 PM in
TVThe problem for me appears to have gone away. I have though switched to using Satellite instead of Terrestial aerial mode. I've also enabled Alexa listening recently, not sure if that helped. Sound from the internal speakers with the TV on its stand and about 30 cm away from the wall behind is really impressive. People have mentioned there isn't much bass from the S95B's speakers but I beg to differ. I've got the sound set up automatically. Hope Nick you resolve the issue.
19-01-2023 01:42 PM in
TVYes, exact same for me. I have sound de/relay all the way back to 240 and the words and gunshots happen before anything even starts on screen. Moving the bar to zero doesn’t change a thing. Is consistently happening through hdmi, broadcast antenna, digital channels, and streaming apps. Brand new TV this month. Customer service has made “tickets” for me 3 weeks waiting and still no word back. Such basic help their screen prompts to instruct customers through the menu are WRONG, have had to correct the agents multiple times for this model. They are giving instructions that would fit my 5 year old Samsung grrrr
sometimes the sound isn’t as bad, almost looks sync’d….then it gets adhd and wanders
19-01-2023 01:45 PM in
TV20-01-2023 04:01 AM in
TVHi all,
Ever since I "reset audio", I have not experienced any out-of-sync between sound and picture so far. I also did not reset the Smarthub. It has nothing to do with the "Digital Audio Output Delay" because that only applies to external connections like the soundbar.
From the feedback in this group, the problem seems to be between the picture processor and the sound processor synchronization and happens intermittently. Let's hope Samsung will catch on to this channel feedback to fix it in their next firmware release.
For those still experiencing out-of-sync picture and sound, try the following:
1. unplug TV from wall socket, let the power drain off the set.
2. turn on TV, don't launch any app and go straight to settings and "reset audio".
3. launch app to see if the new settings get refreshed.
4. if all else fail, our Samsung helpdesk here in Singapore suggested to reset "Smarthub" (which I did not try, because "reset audio" worked for me).
Hope the above will get the gremlins out of your new TV, and truly enjoy what this TV has to offer.
2 weeks ago in
TV
