28-11-2019 01:34 PM
Hey folks
Recently purchased the above TV and am very happy with it. I have paired my existing bluetooth speakers which work flawlessly, but when the TV is turned off, they do not automatically reconnect. I have to go into the settings each time, connect the speakers (which always show as paired) and select this as the default audio output.
I'd really like not to have to do this - is there something I'm missing to make this process automatic?
Thanks!
29-11-2019 04:25 PM
Hey @kanpaaris ,
I would like to get a bit more information about this. Can you tell me which speakers are you connecting to this?
Do you turn on the speakers before turning the TV on? If so, can you try to turn the TV on before and see if the issue persists?
