samsung ru7300 youtube application not working
(Topic created on: 28-07-2020 10:41 AM)
Med-aziz-sol
Hello dears
I bought Samsung ru7300 curved 55"
I cannot install youtube apk
Is showing a message that youtube app is not compatible with this tv
Could you plz help me to install !
1 REPLY 1
CarlH
Hi @Med-aziz-sol. If you're downloading from an external source, it most likely won't work. Is it available directly from the app store? Press the home button on your remote and move the cursor along to 'Apps' or type it on the search bar.
